Buffing/smoothing a painted finish
1/24/23
Dave
Hi. I recently installed a built in with a painted countertop. Countertop was made from Combicore (mdf skinned plywood) with a solid wood nosing. It was primed (sanded) and then painted with 2 coats of Renner pigmented (sanded between coats). It felt smooth to me when I installed, and I'm not sure if the mdf material has swelled or ?, but the client is now saying the surface feels rough and wants something done about it. How would one go about resolving this that doesn't involve A: repainting or B: removing the top. This is a matte/sating finish but would wet sanding at 1000-2000 grit with maybe a light hand buffing with compound after resolve this? I don't want it to become high gloss, just smoother. Any thoughts/suggestions would be highly appreciated.
1/24/23       #2: Buffing/smoothing a painted finish ...
Jared
I don't know Renner but a cursory googling says it's water based poly. Consider shooting a compatible clear satin polyurethane coat or two, and cut / buff the poly to the level your customer's happy with. Put a big fat asterisk on this job for your customer: the clear may change the color slightly, even if it's marketed as "water clear". Most important: test, test, test beforehand. Replicate the combicore to wood nosing joint, and use the same finish schedule as what was used on the original, and get a sign-off from your customer.
1/24/23       #3: Buffing/smoothing a painted finish ...
Mastercabman
This is kind of interesting
I ordered a sample kit from Renner to try out
I sprayed some different type of materials over the weekend
One of the sample I made was a piece of MDF
I also had some doors left over from work orders
I used the 2K primer and the 2K top coat in satin
The finish on the doors looks pretty good However the MDF sample doesn't feel too smooth,not rough but not as smooth as the doors
It seems to be a good product but I think I'll pass
The primer and sealer is pretty thick and the product is pretty expensive
$115/gallon
I'm liking MLC Arroyo better and at a much better cost
Sorry I have no advice for you as I'm new to this brand
Please keep us posted on how you get this solved
Good luck
1/25/23       #4: Buffing/smoothing a painted finish ...
Matt Calnen
Have you tried rubbing it with a brown paper bag? If it’s a satin finish it’s worth a try before refinishing.
1/25/23       #5: Buffing/smoothing a painted finish ...
Dave
Thanks for the input. I haven't tried the brown paper bag. I haven't been to the clients house since I was informed that they weren't happy with the finish. I want to go over there armed with as many options as possible. I will try the brown paper bag first, but my next step is to wet sand with 3000 and 5000 grit sandpaper in the hopes that it will knock off some of the rough spots without hazing the finish. It is a aqua/teal blue. Beyond that, my only option is to go back and try to roll on a coat of the Renner thinned and hope it levels out. A local finisher suggested that, but I am hoping to leave that option for last. I will say, I have used some of the higher end lines of the Renner finish and have been very happy with it. The primer is thick but apparently has some viscosity agents added which makes it pretty easy to spray (I use a pressure pot).
1/27/23       #6: Buffing/smoothing a painted finish ...
Jonathan Mahnken
micromesh purple pad with a spray bottle filled with soapy water
1/27/23       #7: Buffing/smoothing a painted finish ...
caddy Member
Polishing you should paint two coats.
1/30/23       #8: Buffing/smoothing a painted finish ...
scaredharras Member
Customers should be warned that even though the clear is called "water clear," it may change a minor hue shift.
2/10/23       #9: Buffing/smoothing a painted finish ...
Kevin Dunphy
Website: http://kdunphy.com
Polishing is an art
You don't have enough clear or paint just going to highlight the defects
Using MDF is not a good start if you are in that price range meaning cheap customers use laminate save you headaches and give you faster turnaround.
I did laminate countertops with solid wood edging on plywood not making money and gave up .I realize this was a dead end
    • 2Sand
