Milesi questions
5/7/24
Pete
Website: http://cherrybrookwoodworks.com
Looking for some feed back/advice. I've been a custom furniture maker for close to 30 years. My finishes will range from a traditional French polish to spraying solvent lacquers. Every piece is custom color or color matched. I am used to and comfortable with colors/products- Lockwood water stains, Mohawk dyes, pigments stains and glazes. I spray with a 5 stage Apollo turbine which works great for “one off” pieces of furniture. Im not spraying cabinets or large quantities of pieces. I'm starting to look into Milesi solvent products. Has anyone used the mohawk product line with the milesi solvent products? I know the companies say to use their own products but I have too much $ in stains/dyes etc to switch to and that goes for water based too.
The last job I did- mahogany table, water stains for color, lacquer mist coat of sealer, added NGR dye to sealer to adjust color, lacquer top coat. Usually there may be a glaze/pigment color application in the process as well.
I am currently waiting on some info, particularly a PDS sheet, on the milesi line to start doing some samples for myself. Just wondering if anyone is using these products together without issues.
Thanks.
5/7/24       #2: Milesi questions ...
mauricio poli
In my opinion there is no problem.
All you have to do is first to check in scrap panels searching bad adhesion, pin holes, craters, some kind of bad compatibility with your stains and Milesi material. If everything is ok you could finish your furniture with more confidence.
Hugs!
5/13/24       #3: Milesi questions ...
Al
Pete,
I can’t answer your question. I thought regular lacquer was done away with. When I first started I would spray lacquer sealer 50/50 with thinner and then 2 topcoats lacquer 50/50 with thinner. Sanding between coats was easy and quick but not required as next coat burned into previous coat. Does Mohawk still sell products like this? In my opinion still the easiest system to use.
Very nice work that you do.
Al
5/13/24       #4: Milesi questions ...
Pete
Al,
Lacquer is still very much available. But what about a hi gloss, closed poor, durable finish? Regular nitro lacquer is time consuming, even with a grain filler. A more durable finish now has mil limit thickness. Im just wondering what I can and can not do with the milesi solvent vs lacquer.
5/19/24       #5: Milesi questions ...
Chris
I’ve been using Ilva products for past 10 years from camgercoating in Ma. They are very similar to milesi products For a full fill finish I use polyester followed by acrylic urethane I can normally get a full fill with just one coat of poly which gets sanded flat through a wide belt sander benefit is a very durable finish which can be buffed to high gloss The downside is it is harder to repair
6/6/24       #6: Milesi questions ...
Adam Member
Website: https://virmer.com/
Given your extensive experience in custom furniture making and finishing techniques, transitioning to Milesi solvent products could be a promising step. While both Mohawk and Milesi recommend using their own products, mixing and matching can be successful with proper testing. Waiting for the Milesi PDS is wise, and seeking advice from other professionals can offer valuable insights. With your expertise, you're well-positioned to navigate this transition effectively.
6/6/24       #7: Milesi questions ...
George Member
Website: https://wattsan.com/
Experiment with small test pieces to see how Mohawk and Milesi products work together. Check with both suppliers for compatibility advice. Keep detailed records of your experiments, and seek feedback from peers. Aim for consistent, high-quality results that meet your clients' expectations.
8/24/24       #8: Milesi questions ...
Dan
We typically spray Resisitant , it’s a post cat , but recently we have been using some Milesi water Bourne it takes a bit getting used to but seems to be a nice finish product
