Stain match
9/14/25
Hommel Mills Member
I have a picture of the finish on my project and need help to match it. I looked at minwax and others and just can’t find a match. I was hoping someone would help me. Thanks
9/16/25       #2: Stain match ...
Mitch Suber Member
We have two paint stores locally that do our matching. One is a privately owned, a family business that really does a good job. Especially when multiple attempts are needed to get the color tone just right. The other is Sherwin Williams who also does a good job. The process is we provide a sample like a drawer front or cabinet door of the existing color we want to match. We also provide raw sanded test pieces of the wood we will use. So rather than experiment, which we use to do, we have our stains custom mixed. And once in awhile we get lucky with an off the shelf color. Keep in mind how you sand and apply the stain will greatly effect the final color.
9/16/25       #3: Stain match ...
Hommel Mills  Member
Thanks for the reply ! actually found that there has been a feeble attempt to add a shellac. Using a chemical stripper I’ve found the finish under is redish brown possible a mahogany. I have a Sherwin-Williams close by, I’ll let them scan it. Thanks again.
1/11/26       #4: Stain match ...
Michael Member
- the color of the raw wood will have an effect on results.
- is it a stain or a toner. On factory made furniture, toners tend to be used more often as they avoid being effected by wood grain issues.
Our is hard to do this from a photos... especially with a bad finish interfering. (A lot of times you can get a better look at what the color is by wiping the surface with paint thinner - it tends to hide the worn finish and make it more transparent).
Right now I'm guessing you're going to be using a burnt umber with a mix of another color (possibly a yellow... but again, raw wood color plays a part).
Maybe your finish stores are different from ones around me... around me they won't do transparent color matches as their machines don't work with that.
1/11/26       #5: Stain match ...
Yavuz
you cannot find or match because thats not a stain.thats a dye.raw amber foundation and red mahogany or something similar on top.sealer in between :) mostly lacquer for clear coat. Multiple step finishing recipe that professional shops or finishers use. good luck
