Alcohol stain to darken finish
4/6/26
Rov Member
I have a need to darken sun faded walnut.
I have the shade I like using alcohol stain.
question is
Does the stain have to be top coated?
it seems to color and flash off without effect the existing top coat.
thanks in advance
4/6/26       #2: Alcohol stain to darken finish ...
Yes
4/9/26       #3: Alcohol stain to darken finish ...
BH Davis  Member
Once the alcohol stain is dry rub it hard with a rag. If some color comes off on the rag you have your answer. A top coat will be needed. But, even if the stain does not rub off applying a top coat would be advised.
You'll just need to figure out what to use and it will likely need to be sprayed. Brushing or wiping on a top coat will likely move around the color from the new stain.
4/9/26       #4: Alcohol stain to darken finish ...
That's what I said in my condensed answer LOL
