First time restoring - hit a major road bump - please help!
5/14/26
Christine
Hello, I'm refinishing the top of a desk. I had it down to bare wood and properly conditioned it before applying the first coat gel stain, which looked great but still had a couple spots I wasn’t completely thrilled with. I have been using Google Gemini to walk me through this entire process as this is my first time. After seeing the first coat, and knowing I wanted to fix a couple spots, it suggested that I apply another coat after waiting 24 hrs. After the 2nd coat it looked muddy and just not good, so Gemini suggested I immediately use mineral spirits to try remove some of it. That did not go well—it now looks hideous. Any advice on how to proceed would be greatly appreciated.
Attaching photos showing starting point/bare wood, top after one coat, and top after trying to strip with mineral spirits.
View higher quality, full size image (5090 X 3835)
5/14/26       #2: First time restoring - hit a major ...
Yavuz
F..k the Ai and all its kind first of all..
You are at the right place just go this page and look and read and try to understand what you are involve with and how to save your self.
https://www.woodweb.com/knowledge_base/Staining_and_Blending_Difficult_Woods.html
5/14/26       #3: First time restoring - hit a major ...
Christine
Thanks for the info.
5/18/26       #4: First time restoring - hit a major ...
Fred Melton
First get it back to bear wood sand it to 150 wash it down with 50/50 mix acetone xylene let dry try using a good Commerical stain Mohawk it should work much better ,to me it looked like was uneven sanded causing your problems. first time
5/18/26       #5: First time restoring - hit a major ...
Christine
Good tips, thanks Fred.
5/20/26       #6: First time restoring - hit a major ...
Looks like maple. A blotchy wood indeed. Sounds like you are using over the counter stains. Not going to work well.
Use a clear stain base of the stain you plan on using and put it on the top and watch it soak it up. Keep applying to the dry spots to keep them wet. After you have everything wet wipe it down. Let it sit for 2 hours. Then apply the stain. It's going to be lighter than normal because the stain base has taken up all the room in the wood cells, which is also why it won't blotch to badly.
Wait for it to dry and apply a clear coat. If it's too light you'll need to apply a tone coat which is color in the clear. You can't just put stain into a clear coat. Dyes are usually the way to go. Mix up clear with some proper colored dyes and thin the solution about 50% or maybe a bit more. Apply coats until you get the color you want. The do your final clear coat.
If you are brushing this is going to be very difficult. This is a spray method, you sound like a DIYer.
5/20/26       #7: First time restoring - hit a major ...
Christine
Hello, thanks so much for the tips. And yes, I am definitely a DIYer (this is my first attempt at this). I actually had a pretty good result after first using wood conditioner and then applying one coat of the gel stain (see attached pic), but I was trying to fix a couple of minor areas and went back in for a second coat, and that’s when things went south. I was using AI for guidance at that point, and it suggested trying to fix it with mineral spirits, but that ended up making everything much worse.
At this point, I’m stripping and sanding again. I’m not able to get fully back to the pristine bare wood I started with yet, but I’m going to get it as close as possible before moving on to staining again.
5/20/26       #8: First time restoring - hit a major ...
Just be careful if it's a veneer. You only have so much thickness to sand away. If it's solid you don't have much to worry about other than that edge shoulder.
5/20/26       #9: First time restoring - hit a major ...
Christine
I don’t think it’s a veneer but yes, I’m definitely mindful of the edges. Here’s what I was working with after the first strip/sand and here’s where I am now.
