Sata1000k
7/25/26
Mjs70 Member
Does anyone use a sata 1000k?
7/27/26       #2: Sata1000k ...
herb johnson
yup have sata kremlins and a few binks guns
7/27/26       #3: Sata1000k ...
Mjs70 Member
Do you use adapters to connect the bsp fluid and air inlets on the sata to a nps swivel hose end?
7/27/26       #4: Sata1000k ...
herb johnson
many times i just use a tradition nps bps fitting, as they seem to work on either, just my thought...it works on binks guns either fitting works on a binks fluid fitting, did you happen to try it, also titan fittings in colorado has a ton of adapter fittings all stainless
