Furniture Making
Subject: Re: flash drying of improperly kin dryed stock?
3/6/13
Al Ladd Member
I just resawed some 8/4 claro walnut intended for some chests. Material is 7"-9" wide, resawn to 3/4, intended to be used at .7 finish thickness, in lengths 12-19". The boards measured passably dry on the outside (10%, plus or minus one) but inside are more like 13, with some spots as high as 19%. I sealed the endgrain, and have them stickered in my very dry shop (Massachusetts) with a small fan blowing on them. Anything more aggressive that might speed this up (safely)? The job is time sensitive, and I was runnuing late already....Thanks!
3/6/13       #2: flash drying of improperly kin drye ...
Rich
The 12" pieces will probably fit in a microwave oven, 19" not. I've dried woodturning blanks in the microwave quite successfully. You do have to be careful since you can start burning it, and it's like it starts to burn inside the blank, then works it way out. I weigh the board, microwave it for a minute, let it cool, then weigh again. When it stops getting lighter, it's dry. No help other than that when you are on a short date. Buy new stock I guess would be the quickest.
3/29/13       #3: flash drying of improperly kin drye ...
Gene Wengert-WoodDoc
The energy is a microwave is not uniform. That is why most units have an option of a rotating tray.
Faster drying is accomplished by adding heat. To avoid drying the outside shell, keep the environment at about 53% RH.
3/29/13       #4: flash drying of improperly kin drye ...
Al Ladd
Website: http://alladd.com
Thanks for replies. The wood reached acceptable levels in about four days. My shop is drier than 53% for sure. It seemed almost like there were pockets of moisture in the boards, and the levels came down faster than I would have expected. The claro walnut is also lighter in weight than most walnut, and so that probably sped up drying as well.
