Furniture Making
Subject: Re: extra long maple veneer to laminate over plywood countertop to hide sea
extra long maple veneer to laminate over plywood countertop to hide seam
4/19/13
antonio
Hey guys,
I have a job coming up that requires a 15' long x 2' deep wood countertop to be painted white. My problem is i want to construct the top from 3/4" maple veneered plywood but as they only come in 8' lengths i will have a seam that will eventually move and crack at the seam and show through the white conversion varnish finish. I figured to stop this i would laminate a sheet of maple veneer over the seam and then just seam the actual veneer to another piece wherever i need to, i was hoping i could also get away from that seam as well, so my question is , do any of you know if and where i can possibly get a 16' x 2' roll of maple veneer????
4/23/13       #2: extra long maple veneer to laminate ...
Willem J Martins Member
I would join the two pieces with a strip of solid wood, slightly thicker than the ply and splines on both sides fitting into rabbets milled in the ply.
After glue-up you can finish the solid wood strip level with the ply veneer.
4/30/13       #3: extra long maple veneer to laminate ...
Joe Romero Member
I would also do the same as instructed by Willem J Martins and to be more confident while saying this, I have tried it practically and it is perfect solution. You can give this a try from yourself.
4/30/13       #4: extra long maple veneer to laminate ...
Kevin Jenness
Website: birdseyebuilding.com
Try Oakwood, Formwood, and Atlantic Plywood. I suspect it would be a custom order if even possible to get a 16' long sheet but perhaps worth trying. Otherwise, ask for a 4x8 with an even number of veneer leaves so you can buttjoin them at the 8' mark with minimal visual distraction.
I would stay away from a solid wood strip between two sections of plywood- I would expect it to telegraph through the face veneer over time. Just keep it simple and double spline the ply sections directly. Alternatively, skip the ply/veneer route and use an mdf buildup. It should give a better paint finish with far less labor albeit greater weight.
