Furniture Making
Subject: Re: How to make the sliding part of this console
10/14/13
Doug
Website: http://www.cooltimbers.com
My client has designed a project using one element from the attached link. Also this product is not available in the US.
The high gloss piece is actually 1" proud of the rest of the cabinet and slides left and right.
How would you implement this sliding feature?
link to example
10/14/13       #2: How to make the sliding part of thi ...
eddie
Check hafele. I do not know the name of the hardware. What they do have should work for you.
10/14/13       #3: How to make the sliding part of thi ...
mark
A section of channel across the bottom (of the sliding "L") will give you a place to mount two hidden wheels on either corner, and a bit of angle at the top-back edge will hide your other two wheels behind the piece. For the synchronized movement, the best would entail a rack and pinion gear with a fixed pinion (? the cog part) near the slave door, a short rack attached to the slave (teeth down), and a long rack pulled by the master (teeth up). If that all makes sense, then you're good to go. Otherwise, just ask the designer... er: whishful thinker.
10/15/13       #4: How to make the sliding part of thi ...
mark
Just noticed that you're in my neck 'o the woods. If you'd rather outsource the mechanism, then send me a message through Woodweb, and I'll get back to you.
10/15/13       #5: How to make the sliding part of thi ...
doug
Haffle does indeed have hardware for this type project.
10/15/13       #6: How to make the sliding part of thi ...
Charles Member
I think I remember seeing that at the Hafele booth at a trade show a few years ago.
11/6/13       #7: How to make the sliding part of thi ...
Fonkee
I agree with Mark.
