Furniture Making
Subject: Re: Flattening walnut slabs while minimizing thickness reduction
6/30/14
Will
I recently purchased two 20" x 80" x 1 3/8" bookmatched walnut slabs to make a dining room table top. When at the yard, I used a straight edge and deemed to slabs sufficiently flat that using a jig and router would result in minimal thickness loss while flattening. Once I got one of the the slabs on my jig and took a lot of measurements, I came to the realization I would have to remove 0.45" of thickness to clean up all the low points. This would result in a table top that is thinner than I would like. Are there any techniques to preflatten the slab (i.e. steaming, preloading or ?) prior to using the router that would reduce the amount of material to remove? There two problem areas on the slab, one is a small area of excessive cupping and one longitudinal hump. Thanks in advance.
6/30/14       #2: Flattening walnut slabs while minim ...
Fonkijee
I use a CNC to flatten slabs. Removing a half inch or more from one or both sides is not unusual. It sounds like you may have to get by with thinner pieces than you once envisioned for your project, which could be dealt with using clever design details, or perhaps, buy thicker slabs if you have to have thick slabs.
7/1/14       #3: Flattening walnut slabs while minim ...
There is no way to pre-load, wet, or over bend in order to change the set of the boards. The lumber does what it does as it dries and the board is set. Insuring that the green lumber is stacked and stored flat while drying helps, but does not eliminate the tendency to move out of flat, if that is in that boards nature.
You may hear more folklore on this than science. Unfortunatley the folklore just doesn't work.
7/1/14       #4: Flattening walnut slabs while minim ...
Kevin Jenness
Can you live with some unplaned spots on the bottom of the slab? Get it flat enough to run through the planer and clean up the top, with luck the edges will be of consistent thickness and 1/4" thicker than if you completely flatten the bottom. I don't know of any magic tricks other than ripping the slabs, flattening the halves and regluing, which is probably not the look you want.
