Furniture Making
Subject: Re: Glue or no glue
Glue or no glue
10/2/14
daveten
We are building a table for a client and I milled up some extra reclaimed old growth fir for a spec table to do at the same time. The pcs I will use for this top are 6/4 x 12 inches. The top will be held to the base with a sliding dovetail feature and I was thinking of not edge gluing the 3 boards, but just butting tight and using keys top and bottom. Do others use this technique (keys) and no glue?
10/2/14       #2: Glue or no glue ...
ThomasFR
Daveten, Please provide your definition of "keys".
10/2/14       #3: Glue or no glue ...
daveten
I'm thinking butterfly keys, as used for cracks in slab tops.
10/2/14       #4: Glue or no glue ...
As long as you don't mind spilled milk or any liquid seeping into the cracks. Get spilled milk in there and it turns. The smell would not be good. You don't say how long it will be. What keeps the boards in alignment between the dovetails mounts? Unless the keys go through all the way, the wood might twist or move out of vertical alignment. I would glue it if I was building it.
10/4/14       #5: Glue or no glue ...
mark
I'd either glue it or set it with a gap. A tight butt joint does not seem appealing.
10/6/14       #6: Glue or no glue ...
daveten
Mark, true, if no glue, I would leave a gap. The reclaimed old growth fir planed up to reveal flaw free boards, so we glued them up. 36 inch wide top, 3 boards.
1/30/15       #8: Glue or no glue ...
Adela Sabrna  Member
Website: http://www.vellky.com
I was going to use glue, while providing a gap, there is no guarantee for a better look
