Furniture Making
Subject: Re: Table End Extensions
10/3/14
Gary
I have a request from a client to build a dining table that, instead of adding leafs to the center, wants to slide out extensions from each end. They want to avoid storing the leafs "somewhere" ) Does anyone have any hardware or methods of construction for this application? Reference photos ?Thank you
10/3/14       #2: Table End Extensions ...
daveten
Here is a link to a past post on this subject, it's a start...
Link
11/14/14       #3: Table End Extensions ...
Jim Lewis
Mostly I've seen this done by notching the rail to accommodate the leaf. Then you attach guides to the leaf, shaping them at angles so that you can use blocking to make the leaf level with the top when fully extended. I believe the top has to be spring mounted so it can raise, then lower once the leaf clears it.
Wen I've made mechanisms like this, I start with an accurate drawing on the drawing board, then mock up the leaf and guides from thin cardboard. You can then drag them across the drawing and see exactly how they need to be shaped.
If hardware is available, I'd check some place like Selby Furniture Hardware, but I think you may have to engineer it yourself.
If you construct it, I suggest you work it so the leaf mechanism doesn't depend on the top: that way if the top warps the leaf will still work. Not that pros like us ever have trouble with warping tops ;?) but even a little movement can throw off the geometry and it's best to eliminate that issue.
3/4/15       #4: Table End Extensions ...
markbattles Member
Website: http://v-dubfurniture.com
