Furniture Making
Subject: Re: Keyboard slide
Keyboard slide
12/2/14
Ed  Member
Website: http://www.thespeedofwood.com
I'm looking for a keyboard slide that would work in an application with an apron. Imagine a dining room table with a 2½" apron, the keyboard would need to swing down, out, & up a bit around the apron. The other problem is I will only have about 14" of space behind the apron to work with. Everything I'm use to & can find is desk oriented with no apron. Appreciate any help.
12/2/14       #2: Keyboard slide ...
Josh Koschak Member
Can you modify a standard slide with a "flip-up" apron? In other words, you pull the slid out then hinge down the apron, which would act as a wrist support. This would allow you to be focusing on just a linear movement for the keyboard.
12/3/14       #3: Keyboard slide ...
AzFred  Member
Cut the Apron like you would for a drawer front and use it with the flip front slide shown in the link????
Selby Link
12/8/14       #4: Keyboard slide ...
D Brown
Here is one of the flip down key board slides
Not a real precise piece of hardware but it did the job.
12/8/14       #5: Keyboard slide ...
Ed  Member
I came up with something that might work pretty cool. Some Hafela bored in flap hinges and Fulterer slides that lock in the out position. I'll post some pictures if everything works out.
