Furniture Making
Subject: Re: Setting multiple spindles at once
4/28/16
Lucas Member
I am in the process of nailing down a production process for a rocking chair that my company is producing. One of the last major challenges involves setting the chair's spindles into their respective mortises. Essentially, the design and joinery require me to sink most of the spindles into their mortises all at once as to avoid dragging them across the wood. So far, I haven't thought of a truly great way of doing this. I've tried making what is basically a large wooden comb to hold the spindles in their correct positions so that they can be pressed into the seat. I've also considered making a mold that would hold the spindles where they need to be. Any recommendations?
6/2/16       #3: Setting multiple spindles at once ...
B.H. Davis Member
Assuming these are round spindles why not just take a piece of 3/4" ply and drill holes at the correct locations. Then band saw across the entire length of the board going through the center of each hole.
This will give you two halves that can be clipped together around a set of spindles and then after the install be removed by releasing the joining hardware.
Think of colonial era punishment stockades with hand and head holes.
