Furniture Making
Subject: Re: Table top table makers
10/8/18
Brent
Table makers-have you experienced any problems with a glued up top around this size?It's 54x54 6/4 hard maple with no bread board ends. It will show end grain. There are no legs it will sit on 12in.centered pedestal.
10/9/18       #2: Table top table makers ...
David R Sochar  Member
What problems are you experiencing?
10/9/18       #3: Table top table makers ...
Cbww
At that width in maple and not knowing the design of the base- I would be afraid of that top cupping with a change in humidity. Are there some form of cleats on the underside? Maybe veneer the top on plywood? even if there are bread board ends, I have still had a table cup a decent amount and flex that bread board end with it. But they have been easily flexed back down to a table frame when screwed.
10/9/18       #4: Table top table makers ...
Brent
No problem yet , I've never made a top like this. Just wondering if there is any problems later on or anything that I might prevent when making the top? Thanks for the look.
10/9/18       #5: Table top table makers ...
Brent
This table top sits on a 12in. Square pedestal that stands on a 36in. Sq. Flat base.
10/9/18       #6: Table top table makers ...
Hopefully you will have some bracing to the base and top. If you don't, you'll have more problems with the pedestal than the top. People lifting themselves out of a chair by pushing down on the table top can really exert a lot of load. Americans aren't getting any smaller either!
10/11/18       #7: Table top table makers ...
BH Davis  Member
I agree with Rich C. on the base design. Design in some cross bracing at the top extending out from center at the very least.
As to the top would you be able to use quartered or rift maple? That would make the top more stable and less likely to cup.
Also important will be to apply equal amounts of finish to both the top and bottom surfaces.
