Furniture Making
Subject: Re: How Much Time to let Glue set before Machining
11/8/18
Howard
Typically when I do a glue up I will let it sit overnight to gain better strength before sending it through the planer. I am getting very busy lately and was wondering if I really need to wait overnight, Titebond says to give it 24 hrs. I didn't want to change my approach and risk a joint failure before checking with you folks first. Appreciate your thoughts. Thanks
11/8/18       #2: How Much Time to let Glue set befor ...
duster
I wouldn't worry about a glue failure. I would worry about sunken glue lines on your panels if you plane and sand too soon. Water based glues like Titebond will slightly swell the edges being glued. After drying completely, the edges will shrink back to their original dimension and you can safely machine them.
I learned the hard way years ago, when I'd try to glue up, plane, and sand panels the same day. It looks fine then, but a few days later after the finish is applied, the glue lines will be slightly recessed.
It doesn't happen all the time, but a table top or raised panel door with sunken glue lines is not acceptable. It's more prevalent with softer woods like alder, poplar, pine, ect. but it can happen with harder wood also.
If you have to remake a batch of doors because you were in a hurry, you're not going to save any time or money...
11/9/18       #4: How Much Time to let Glue set befor ...
Jim Clark
I think you need the 24 hrs recommended,
as a minimum. For table tops and
doors I like a little longer, but never less
than the 24 hrs.
11/9/18       #5: How Much Time to let Glue set befor ...
Howard Member
Thank you for your help!
11/9/18       #6: How Much Time to let Glue set befor ...
I'm running panels through the planer after an hour. But then I let them sit for about 3 days for the water in the glue to dry out before they get sanded.
While they are "curing" I'm making other parts for the doors and drawer fronts.
