Furniture Making
Subject: Re: General 3hp Dual Drum Sander
9/25/19
Howard
Website: http://woodcontours.net
I am at my wits end, the conveyor switch is not working and now the switch for the drums seems to not be working properly. So what I would appreciate is can I get a sense of what I propose as a solution will work - I am going to remove all the switches. I will attach a separate 20amp switch that will power the drums. For the conveyor motor, I was thinking of attaching one of the variable speed controls that you can buy separately for routers. Doing all the wiring I can do no problem, I just want to be sure this will work before I dump money on this. I have had too many projects start to go through the sander only to have the conveyor stop. Thanks for your help.
9/26/19       #2: General 3hp Dual Drum Sander ...
Not sure about the general but you may want to check to make sure your conveyor runs on an AC motor. Most I have ever seen run on a DC motor and if so your router speed control wont work. The main drums would seem nothing more than a switch or contactor.
9/27/19       #3: General 3hp Dual Drum Sander ...
John Member
Why don't you just change the switches? I bought a new one for the conveyor drive on Amazon for maybe $10 when mine failed; same 3hp General as yours.
John
10/9/19       #4: General 3hp Dual Drum Sander ...
Ken Member
Most router speed controllers work with AC/DC universal motors but are a far cry from an industrial speed control like a VFD which would give a more consistent speed. That said why not address the problem and trouble shoot the switches. If they're bad replace them with a higher quality switch.
