Furniture Making
Subject: Re: questions about ash
questions about ash
10/14/19
duster
I just got an order for an ash dining table.
In 35 years I've worked with everything from anigre to zebrawood, but never ash. I'm wondering what to expect as far as machining qualities, sanding, wood movement, finishing. Any advice or thoughts would be welcome.
10/15/19       #2: questions about ash ...
Paul Miller
Ash has been called "Poor mans Oak". You won't have as uniform color as Oak. but the grain is similar and machines similarly. Ash, when on the stump or in the forest, has a lower moisture content and if you need wood for firewood and you did not have time to split and stack it to dry, you could use Ash.
With the Emerald Ash Borer, you may have some pin holes. I would be sure to use only kiln dried wood.
10/15/19       #3: questions about ash ...
Similar to Paul's response, not much in the way of surprises in that it pretty much works like most of the domestic hardwoods. The Emerald Ash Borer is up in the bark/cambium layer. Not that you may not have some holes in the heart wood from other issues but the main issue with the EAB around here is it has driven the price of Ash up far higher than FAS Cherry at the moment. There isnt a live tree anywhere around here. Most of the commercial loggers have stopped cutting it at this point as its almost impossible to get them down without the tree busting to pieces. Standing/dead, pretty dry, and they are brittle when they hit the ground.
Tends to take stain far more dark/light but still very even. You shouldnt have any trouble if your accustomed to other domestic hardwoods.
KD would be a given hopefully though there are a lot of people doing a lot with thick air dried slabs. Not my cup of tea.
10/15/19       #4: questions about ash ...
Mark is right - the EAB is up in the crown of the tree, living just under the bark, eating that juicy part of the living tree.
The Shrinkulator will tell you, but I think Ash moves more than most woods. I have often cut out parts and let it sit overnight. The next day, the endgrain of half the parts has checked. My response? Ignore it. All went well.
I have planted several hundred trees on my property. About 16 were Ash, planted about 25 to 30 years ago. 12 have died, but 4, all purchased as little "sticks" about 25 years ago, have thrived and show no signs of the EAB, even though it is active 200' away.
It is now believed that about 12% of the native Ash population has some resistance to the EAB. Hopefully, these trees can hang on and provide more young trees that are also resistant. The Ash I have are magnificent shade trees with low trash, good wind resistance, and perfect globular shape.
10/15/19       #5: questions about ash ...
I work a lot with ash. My last load of 8/4 was definitely EAB victims and maybe dead standing. Ripping the big boards was tough. The tension closed the kerf in the first three inches of the cut and the bow that resulted was about an inch in ten feet in some boards.
10/15/19       #6: questions about ash ...
duster
Thanks for the responses. My lumber was just delivered, and it looks pretty good. The boards are 14' long, flat and straight, no evidence of holes from EAB. It is heavier than I expected. The finish requested is a somewhat mottled, milky gray with some distressing. My finisher doesn't anticipate any problems achieving that.
The table won't be delivered until mid December, so I think I'll mill some parts and panels and let them sit for a few weeks to acclimate to the high desert environment we're in.
10/15/19       #7: questions about ash ...
You shouldnt see any holes from the EAB anyway. They live just under the bark and they devour the cambium layer which then starves the tree to death. When you see the logs down the bark will be rolling off and you can see all the tracks beneath the bark but they dont get into the heartwood at all (not that something else might).
Your main issue as Tom noted is that if your boards came out of trees that were dead, or dieing, the tension in the logs can be an issue even after kiln drying as many trees can be pretty darn dry when they hit the ground as Paul mentions. Its one of the trees that if your short on firewood you can cut/burn it with relatively short seasoning.
You wont know til you start cutting it up.
10/15/19       #8: questions about ash ...
John Member
I've milled quite a few EAB killed trees that stood dead for a year before being cut down. Most all had some staining I them, compared to ash that's cut when still alive. If your wood is consistently white or cream colored you shouldn't have any trouble with it if it was dried properly. White ash has about the same seasonal expansion/contraction as red oak, and works and finishes similarly, too. It's just slightly harder on the Janka scale, but not quite as dense.
John
12/16/19       #9: questions about ash ...
duster
Here's the finished table, shown with the leaves in. It's 8' long without the leaves, 12' with. I used steel Watertown extension slides, 6' long closed and 10' long open. Strongest and smoothest slides I've ever used.
View higher quality, full size image (800 X 455)
