Furniture Making
Subject: Re: Thinking of CNC Machine
6/17/21
howard gorman
Website: http://woodcontours@gmail.com
I would like to purchase a machine to do small carvings that will go on some of the products that I sell($2k-$3K). This will not get heavy usage, a few runs a week. Budget is key I'm a one man custom shop. In this price range can you get a reliable machine? If I need to go a bit higher, by how much? What brands would you suggest I look at? Thanks
6/17/21       #2: Thinking of CNC Machine ...
Your estimate is off by a factor of 5. You could buy a hobby machine and make it work slowly and with constant attention but I wouldn't go that direction. I paid $35k ten years ago and the cnc was paid off in under two years with the added value to the shop.
You would be hard pressed to find software to draw and control the cnc for $2K.
My advice is to invest as much as you can into a cnc as large as your space will allow because it will be reliable, be structurally strong enough to produce quality results in a reasonable time.
8/3/21       #3: Thinking of CNC Machine ...
Kris
I would also suggest to find something heavy. If you are handy, a used machine can be a great option. With a heavy machine, things will stay put, and stay in tolerance.
Also, pay attention to how much time and effort you will have to put into changing a tool.
If you have to manually install every tool and measure/touch it off every time, it's a whole lot of work.
If you can get a machine that will take tool holders you'll be several steps ahead.
A machine with a tool changer and you'll be miles ahead.
That won't necessarily come cheap though, unless you are able to find a diamond in the rough at an auction, and are handy enough to get it going.
