Furniture Making
stability of a table
2/21/17
Tomasz
Hi,
I'm making a table and I wonder if it will be horizontally stable. How can I calculate/estimate this?
Here are the details:
The table width is 160cm, depth 70cm, height 76cm.
The table top is 6cm thick and is made out of block-board (14mm pine core + 2mm birch + 1mm oak veneer). It's empty inside.
The table legs are 70cm tall and 70cm wide. They are made out of a stainless steel closed profile (width 4cm, depth 2cm, thickness 0.2cm).
I attach the drawing for clarity (all dimensions are in cm).
I would be grateful for any suggestions.
With kind regards,
Tomasz
View higher quality, full size image (451 X 399)
3/11/17       #2: stability of a table ...
Jan
Website: http://www.fowfurniture.com
Here is a link to a post that may help you out: http://www.eng-tips.com/viewthread.cfm?qid=377890
To find the densities of various wood species, go here: http://www.engineeringtoolbox.com/wood-density-d_40.html
