Furniture Making
Veiling lacquer
10/14/17
MSC Member
Guys, need your help. What was the difference between regular lacquer, and the paint that was used in veiling lacquer. I cannot find any info on this at all. I need a veiling paint. I know that there is something you mix in with lacquer to make it have "memory" or more stringy. from what I hear there was an additive. They used this technique on lampshades in the 50s and the veiling stain on wood. Any help would be amazing. Thank you so much!
12/7/17       #2: Veiling lacquer ...
Shane
it was a viscosity thing...... I've heard you can break up Styrofoam cups and let them melt into your nitro lacquer to give it more body so it will veil properly.. obviously you have to have the correct gun setup.. binks still makes it for the 2100 pressure setup gun
