Furniture Making
How to rubberized sanding table top
1/31/18
Robert Member
Hi all !!
Anyone can advise what to buy, I intend to build my own downdraft sanding table and wish to rubberize the « perforated » top !??
Thks
2/1/18       #2: How to rubberized sanding table top ...
Robert Member
Have you considered using cork as opposed to rubber ? If you have your mind set on rubber type of material, try those 3'X3'X1/4" mats you can get at an Automotive FLAPS. They usually come in sets of 4 or 5 and hook together like a puzzle.
2/1/18       #3: How to rubberized sanding table top ...
Robert Member
Tks Robert, but yes I've tried, simply not durable, maybe for hobby, but for a shop ! !
Good luck !
2/1/18       #4: How to rubberized sanding table top ...
Robert Member
On a side note, you can get rolls of cork 24"/ to 36" wide and up to 1/4 " thick. Its pretty beefy. Just a thought.
2/5/18       #5: How to rubberized sanding table top ...
DOM
Website: http://naply.com
Spray on bed liner
2/5/18       #6: How to rubberized sanding table top ...
nicko
check out Plasti Dip. I think you can buy it in gallons at big box stores.
nicko
2/6/18       #7: How to rubberized sanding table top ...
Black rubber sheet is available from koi pond dealers. It is about .100" thick and comes in large sheets and is inexpensive. How you put it down and put in the holes, I'm no help.
2/6/18       #8: How to rubberized sanding table top ...
Pete D
What David's referring to is EPDM rubber membrane. It's used for pond liners and low slope flat roofs. Firestone warranties their membrane when used with some of the most noxious adhesive I've ever been exposed to...I've installed it on several roofs. I assume regular contact cement would hold fine. While it's easy to cut with scissors or a sharp knife, boring holes is a little different. If adhered first to a solid substrate a sharp hole saw bit would probably cut through no problem, but the edges may or may not be clean. A sharp hole punch would probably be necessary for clean edges although I can't imagine it would matter too much.
I use a rubber mat with holes supplied by Denray for polishing stainless on my metal downdraft table. It's a few bucks per sq/ft and can be cut to any size. The rubber is more rigid than EPDM if that's a concern.
You might also search for rubber flooring mats, there's tons of options from foam to rubber in different thicknesses and densities.
3/6/19       #9: How to rubberized sanding table top ...
Jamie
Website: http://www.thisendup.com
If you are building it, go with the rubber membrane. I've tried plasti-dip, vehicle undercoating, aerosol rubberized paint, roll on flex seal. The best is to just use the membrane and adhere it to a good sheet of plywood that has your holes already milled into it. After that you can drill a hole through the membrane and use a flush trim bit to match the membrane to the holes underneath. Its messy, but it works and you won't wear one out of years and years.
5/28/26       #10: How to rubberized sanding table top ...
irtubes  Member
Website: https://irtubes.com/
You might want to look at industrial rubber sheet materials rather than trying to coat the surface directly. A thin abrasion-resistant rubber layer can help improve grip, reduce vibration, and protect workpieces from scratches while still allowing airflow through the perforations.
Depending on the sanding dust and shop conditions, materials with good wear resistance and flexibility usually hold up better over time. Some people also use perforated rubber mats or bonded elastomer sheets instead of spray-on coatings because they’re easier to replace later if they wear out.
One thing to watch for is making sure the rubber surface doesn’t become too soft, otherwise fine dust can embed into it over time.
