Furniture Making
Two part Resorcinol glue and exterior wood species.
10/23/26
Hello everyone. I am looking at making a two person glider and two rocking chairs to go outdoors.
In my area of Chicagoland, it seems to be very difficult to find anything other than plantation teak. Even then, it’s difficult to find longer, wider and thicker boards, i.e. up to 8/4.
After speaking with the general manager over a wood plant department at a solid wood supplier, he recommend recommended I look at using IPE, genuine mahogany or sapele. IPE also seems difficult to get as well.
What are your guys thoughts about those three wood species being used for exterior furniture?
He also suggested I could use a clear finish that is like an oil from Olympic to protect it, but it would require probably yearly or every 2 years maintenance.
He recommended I use Resorcinol glue and not Titebond ll.
My customer initially wanted me to use Teak, but from my understanding, we are at a trade war with the country we get tea from and it is very difficult to get. I don’t know how much truthfulness there is to that.
Thoughts? Ty
10/24/26       #2: Two part Resorcinol glue and exteri ...
Old growth teak is rare and expensive regardless of tariffs. I would choose sapele of the recommended alternatives or white oak.
You can use epoxy, plastic resin glue or polyurethane as a weather resistance adhesive. Make sure you choose the product that will give you sufficient assembly time.
Any exterior wood finish will require annual attention. Encourage the customer to store the pieces out of the elements in the winter.
