Subject: Re: painted face frames
painted face frames
8/15/12
chich Member
need info from the pros so here goes. I want to make a melamine box and then fasten the prefinished (white) face frames that will be painted both sides. What I do is I make a groove the thickness of the biscuit on the back of the face frame and then have a correspondinggroove on the cabinet edge to receive the biscuit . My dilemma is once I paint over these grooves will the glue still hold the biscuit in place. I think not. Dont want to handle the finished face frame and th biscuit machine at the same time for fear of damaging it
8/16/12       #2: painted face frames ...
John Langley
Chich - Why are you painting the back of the face frames? Put masking tape over the groove or stick a temporary spline in the groove.
8/16/12       #3: painted face frames ...
chich Member
thanks John. I run a continuous groove around the face frame with the table saw the thickness of the biscuit so that when Im ready to fasten I only have to cut biscuit s in at random on the case with out all the calculations. I feel it's more accurate also. I paint the back of the face frame so that I dont have to hear from the peanut gallery. Masking tape sounds good
1/1/25       #4: painted face frames ...
Donald Wiggins
To ensure strong glue bonding when attaching prefinished face frames to a melamine box, avoid painting the grooves where the biscuits will fit. Mask off or sand the painted areas before applying glue. Consider using clamps or a jig to avoid handling the finished surfaces. If needed, use screws or dowels in addition to biscuits for extra holding strength.
