Subject: Re: Wall mounted closet
Wall mounted closet
9/12/12
Jordan
I am trying to design a wall mounted closet for my room. I have thick carpets that I don't want to cut away for anything standing. Below is a picture of sort of what I want to do. The only thing is, I don't know how this was installed. Are the shelf dividers attached only to the cleats on the wall? Is there some way to hang these divider boards on the stud itself. I don't see any hardware like an L bracket on these boards. What is the best way to approach this?
Thanks in advance for your help.
View larger image
9/12/12       #2: Wall mounted closet ...
mastercabman
Looks to me that those vertical pieces holds most of the weight.look at the bottom at the wall.Then it is secured at the top with cleats.
All of the shelves are problably dado into those vertical piece.
Looks like Gary katz in that picture!!!!!
If it's him,i would simply just ask him how he did it!
9/12/12       #3: Wall mounted closet ...
mastercabman
Looking at the pic again,i think the shelves are held by cleats,not by dados?
9/14/12       #4: Wall mounted closet ...
eddie
If you don't want anything on the floor for support. (The pic looks as if the verticals are on the floor.) Use one of the hanging rail support systems.
9/14/12       #5: Wall mounted closet ...
chich
Just a guess. Id say from the picture this unit is 48" wide or maybe 64" wide because of the angle given. In that case they make a small piece of hardware that would be mortised into the back of the 3/4" uprights and hung on a screw that would be fastened to the studs on the wall. Unfortunately I dont know the name of this inexpensive piece of hardware but hopefully these other experts on here can enlighten you
9/17/12       #6: Wall mounted closet ...
Bruce H
you might want to try Fine Woodworking. com, their ask and answer website would be more suited to your question.
9/17/12       #7: Wall mounted closet ...
wmsuber
Jordan, we hang a good many wall mounted closets using horizontal cleats. These are usually the same material used for shelves and verticles, cut 3/4" x 3 1/2 or 4" and the same length as the shelf they will be under. We apply at least 1 in every section, hope for 2 per section and will apply 3 if possible. To get the best fit and appearance, we cut these along with the shelves. We screw this to the shelf they will be under, and when possible, will screw thru the verticle into the end of the cleat. They may not sound like they will be strong, but they are. By using cleats in every section, you will be attaching into every stud that is behind your unit, often in a high and a low area. It is usually only in a shelf stack or a shoe stack where you can use 3 cleats in the one section. Also since they are screwed to the wall, pick only fixed shelves to screw to.
9/17/12       #8: Wall mounted closet ...
Jordan
Thanks for the responses I think I have a good idea how I'm going to do this.
Thanks again.
10/18/12       #9: Wall mounted closet ...
jason holtz
I've hung closets with a top and bottom mounted cleat like in the photo. You can hit studs where possible, and we use these anchors where there's not a stud
strap toggles
7/4/13       #10: Wall mounted closet ...
steven Member
As a trim carpenter I've built countless closets using that same method. No need for any fancy hardware or even for the dividers to rest on the floor or be over a stud. All eight of those wall cleats are probably nailed into a couple of studs. Dividers were then nailed to probably all the wall cleats. Side cleats were then glued and brad nailed into the dividers. Shelves were then put in an nailed off to wall and side cleats and possibly through side of dividers into shelves if they wanted to go crazy with the nails. Everything would then be tied together and pretty rock solid. I highly doubt even Gary Katz would dado those shelves in; there just for shoes, sweaters, etc. and doing a closet like that doesn't exactly call for any special joinery. That's what the cleats are for.
