Subject: Re: Aluminum Straightedge
12/17/12
JB Dyer Member
I am in need of an 8 ft. piece of rectangle box tubing to use as a straightedge for cabinet installations, anybody got a source? An 8' level may work also. What are you other cabinet installers using to maintain level over this distance. thanks
12/18/12       #2: Aluminum Straightedge ...
JeffD
I use a 78" door jamb level for that particular purpose. I do also have aluminum rectangular tube that's 1" x 4" x 8' for when I need to check something for a straight edge. I wouldn't trust it for super high precision, but it's accurate enough for most shop things. I bought it online from online metals.com and it was pretty reasonable at the time.
good luck,
JeffD
12/18/12       #3: Aluminum Straightedge ...
franko64
I prefer the Stabila plate levels. Awesome tool.
12/18/12       #4: Aluminum Straightedge ...
mastercabman
"What are you other cabinet installers using to maintain level over this distance. thanks "
A laser!
12/19/12       #5: Aluminum Straightedge ...
JB Dyer Member
Thanks All, I bought a 8' stanley level at Lowe's for $90 plus tax used it today and made a big difference. I install factory low end cabinets, always lots of little boxes to put together and this has helped maintain level over 3-4 boxes. Its fast and cheap and works.
12/21/12       #6: Aluminum Straightedge ...
Patrick Member
I buy 2-1/2" x 3/8" thick extruded aluminum flat bar. It comes in 20' lengths and the local steel company will cut it. I carry a 4', 6' and 10' for large runs. Here a 20' piece is $60, much cheaper then any straight edge and just as accurate. Also it's easy to drill holes through and cheap enough to be sacrificial if needed.
12/22/12       #7: Aluminum Straightedge ...
rescraft
Steel studs; cheap ($4-7) and straight.
12/23/12       #8: Aluminum Straightedge ...
Dan / drbwoodworks
Really steel studs ? We use 8' stabila level , laser or the long festool rail, in a jam , use engineered 2x4 s any good lumber yard will have them , as for material from a metal yard the longer the piece is it starts to go to one side or the other , might need to be machined.
12/26/12       #9: Aluminum Straightedge ...
Bruce H
I use MDF with high pressure laminate glued to both sides (leftover pieces from our products) I start with a pice about 8" wide and re-machine the edges as needed with the CNC.
1/1/13       #10: Aluminum Straightedge ...
8' is not that long. Why not simply straighten a stick of wood on the jointer? It will be straighter than most of the extrusions people mentioned.
1/3/13       #11: Aluminum Straightedge ...
mike
In a pinch, theres always the old string and 3 blocks, and probably the most accurate if your just looking for a flat plane...built a many metal frame bulkheads in the day with just that.And dont forget the old plastic tube and water..Still find that to be very accurate if I am doubting my laser!! and goes around corners without moving the set-up,we still carry one in the install truck..
1/12/13       #12: Aluminum Straightedge ...
Randy
8' Stabilla
But I LOVE my johnson lazer level.
1/27/13       #13: Aluminum Straightedge ...
steeliemark Member
+1 on a piece of jointed stock. I edged a piece of 1" plywood with 1/2" of mahogany and jointed 1 edge straight, planed the other parallel, hand holes to match my Dave Crick 4' level. Only out the time to make it and it's been good for several years now. Have one for jambs too.
Unfortunately, things like aluminum extrusions - or anything with scrap value- have a habit of growing legs these days.
I always used to screw as many boxes together as I and a helper could lift first, then put them up with jacks, easier to level up. But everyone has their own methods.
