Subject: Re: Small gap at between Face Frames
3/8/13
Mark C  Member
My company is doing it's first cabinet install using a manufactured cabinet. There is a 1/64" gap between the Face Frames in some spots.
My carpenter says the Face Frames weren't quite straight and we need to use matching putty and fill the small gaps.
After thinking about this situation, I have a theory. I am hoping someone has some experience in this area.
We used Pony clamps to fasten the cabinets. The first time he used them he split the frame and said that the Pony clamps put the hole too close to the edge and that was the reason for the split. He started using the clamps for alignment only and hand drilled the pilot holes away from the clamp.
My thought is that there is a small gap because he isn't drilling right where the clamp is putting it's pressure. Then the threads of the screw are actually holding the two pieces apart?
I know putty must be used in some cases, but I would like to avoid using it on the Face Frames if possible.
Any help on this matter is greatly appreciated.
Mark C
3/8/13       #2: Small gap at between Face Frames ...
JeffD
Sounds to me like your problem is the installer. When everything else is causing problems that usually means the guy doing it doesn't know how to do it properly.
For instance, faceframes aren't perfectly straight? Break out a block plane and one or two swipes has them straight! You should need clamps only for pulling and holding the 2 cabinets together, NOT to straighten the faceframes! If your trying to force the faceframes straight by clamping and screwing I think putty is the least of your problems! And there has got to be more than a 1/64" gap as you could close that just by hand pressure? Hard to advise any better than that without actually seeing the problem, but it sure sounds like the installer to me.
good luck,
JeffD
3/8/13       #3: Small gap at between Face Frames ...
Gerry
Often when you pilot a hole when two pieces are being held together you get swarf between the two pieces when the bit comes through the first piece this will hold the two pieces apart if not cleaned out. Another problem is if your pilot is not over sized in the first piece and you screw is threaded all the way up it will not pull the two pieces together.
A installer who is not aware of these problem either doesn't have enough experience or doesn't care.
Gerry
3/8/13       #4: Small gap at between Face Frames ...
Jerry Fartwell
Get a new installer. Don't putty the face frames. Pull out the screws and fix the problem.
3/9/13       #5: Small gap at between Face Frames ...
mastercabman
I also think that the installer is the part of the problem.
Those pony clamps you use,Are they the
"face frame pony clamp"? If so,i got a pair of them and used them for about 2 weeks,that was years ago.I use kwikclamp made by BESSEY and use a 4mm bit to drill my holes.I also use 2.5" square drive screws to attach cabinets to each other.
3/9/13       #6: Small gap at between Face Frames ...
mark
Some good ideas here, but they all seem to be affected by the op's pawning off of responsibility.
Mark C., your description of the situation suggests that you don't have much experience with cabinet installation, and that you're trying to get out of paying for skilled and knowledgeable help. I could be misreading the situation, but this is what I think:
1. Filler is for under finishes in places where there is no possibility of unevenness in the movement of the surrounding material.
2. Clamps are not fasteners, clamps are not drills, clamps are not cabinetmakers.
3. Your carpenter would likely be put to better use on other tasks.
4. If you don't know how to drill a pilot hole and put in a fastener, then you should hire someone that does.
3/9/13       #7: Small gap at between Face Frames ...
Robert
I guess when I read manufactured cabinet...I think cheap and to be honest 1/64th on a cheap cabinet, well I think you got off easy. All these guys are giving you great tips for someone spending money, but if this is "cheap" then 1 /64th is nothing, less than nothing and when the tops are on and no sunlight coming through you'll be fine.
Some guys on here forget you get what you pay for. If you are hiring a guy at $30-$40 bucks a box be happy you aren't seeing 1/16th+ gaps.
Just my two cents....
3/14/13       #8: Small gap at between Face Frames ...
Jeff M
If your screws are pulling tight with no debris between the frames and you still have a gap, that's a good sign that your frames aren't straight enough. As mentioned above, straighten them out after some trial fitting. You should be able to pull two stiles together tight with just a couple of quick grip clamps and a couple of screws. Make sure your counterbore is deep enough so the screw thread will catch enough meat of the wood not to strip out.
