Subject: Re: RE: Flooring-- Tongue & Groove and Relief Cuts
10/10/13
Ken Member
What is the best relief cut for wide plank flooring (7” to 12” wide)? How deep & how far spaced?
Should the tongue be slightly undercut to fit the groove better?
11/14/13       #3: RE: Flooring-- Tongue & Groove ...
rileycooper
First see the damaged flooring and decide how much length to remove then draw a line to cut use a sharp chisel through the top 1/8 in of the flooring to create a crisp edge that defines the new butt joint.
12/18/13       #4: RE: Flooring-- Tongue & Groove ...
Our reliefs are about .080 deep and start 1.00" in from groove .250 wide and .750 between reliefs. Lay it out on paper. It is not critical but the relief cutter for on the inch sizing will not work for on the half inch. Example 7" face vs 7 1/2" face if you ever cut on the half.
Large mills cut the relief to cut down on shipping cost and gain fuel for there kilns. We cut them to help reduce cupping and add a channel for glue squeeze out when installing plank. The vertical section under our tongue is cut back 1/32 to make sure the top of the boards close. Our groove is .188 off the table and the bottom of our tongue is .003 to .005 higher. The groove is cut .250 wide and .250 plus 1/32 deep.
The tongue is cut .250 deep and .010 to .012 smaller then the groove. Tongue has a radius end, 1/8" R.
Make sure your cutter stay sharp. If they start to burn the installers will have a lot of trouble since the dull cutter is compressing the wood and when it springs back it is to big and will not fit easily into the groove.
