Subject: Re: pull out sutting boards
4/28/15
Chaim gottesman  Member
Website: http://www.ltccarpentry.com
Hi,
A client has asked me to install a hardwood pull out cutting board in the kitchen I am making for her and I have never added this detail to a kitchen before.
She needs the ability to remove and replace it for easy cleaning.
I was thinking of slotting the sides of the board and having it ride on either wooden or a metal angle iron mounted inside the cabinet.
What kind of a stop can I use?
alternatively I could install it in a shallow drawer but I feel that this would move whilst cutting so I am hesitant to go that rout.
Any suggestions for this detail would be appreciated.
Am I over thinking this?
Chaim
4/28/15       #2: pull out sutting boards ...
D Brown
With face frame cabinets if the top rail of the base cabinets is 3" or whatever I run a dado in a board that runs on each side .It is between the face and the back rail .Just needs to clear any drawers.
You can add a face to the board so it stops agaist the cabinet face or you allow the board to stop itself against the back rail or added stops inside.Hope that helps .
4/29/15       #3: pull out sutting boards ...
Bruce H
You are over thinking it. Call you hardware supplier and purchase a set of bread board runners, screw them into the cabinet, order a cutting board and put it into the slot.
4/29/15       #4: pull out sutting boards ...
Jim Herron
Accuride 340 butcher block slide with lock out detent.
4/30/15       #5: pull out sutting boards ...
Thanks for the responses,
There are a couple of things I should mention, the cabinets are frameless and I am out side the continental USA.
I did however have a thought on the stops!
I can use the old trick of slotting the sides of the cutting boards, having them run on hardwood runners and slightly recessing a dowel in the cabinet side as a stop.
I can then simply screw a thin slat to the back of the cutting board which will engage when it hits the dowel.
If you want to remove the board from the cabinet you simply access the slat from underneath and turn it away so the cutting board can slide out.
In any event I'll be checking with my supplier to see whats available.
