Subject: Re: Air compressor
Air compressor
12/4/20
What compressor are you using on site for install, spraying touch ups, etc.
I am looking for a fairly portable compressor that has a fair bit of CFM.
I currently have a senco 1 hp or maybe a little smaller, runs a Brad nailer. I have a 2 hp makita, runs a couple brad nailers, I have an eagle wheel barrel compressor, runs a few different air tools. The wheel barrel compressor is a pain to move and very heavy.
I was looking at a couple bigger makita compressor’s, not sure if they would be better or not? You always have to keep in mind power supply on sites as well, can’t be blowing breakers.
Just looking for ideas.
12/4/20       #2: Air compressor ...
Josh Koschak
Can you plumb in a second take between your gun compressor, you can use quick disconnects and it will give you the volume you need for short bursts and let it catch up when necessary.
12/5/20       #3: Air compressor ...
Jim Clark Member
You should be able to get up to a 2 HP
and still run on 110 current.
Any saying they are bigger than that on
110 current are lying.
12/5/20       #4: Air compressor ...
rich c
"Fairly portable" and a "fair bit of cfm" are tough parameters to help you with. You need to make a list of tools and cfm consumption. Then decide how many tools will be used at the same time. Easy to size after that data. Be sure to also check duty cycle on the smaller compressors.
12/7/20       #5: Air compressor ...
Have you considered going this route instead?
HPLV system
12/7/20       #6: Air compressor ...
MarkB Member
Yeah.. Bill has the answer. If your actually needing to do any on-site finishing that isnt AAA with ultra low volume air, a turbine kills the bulk of your air demands. When we did onsite work it ranged from simple two cylinder hitatchi oiled that ran for perhaps 18-20 years without a hitch, multiple guns, never an issue, to a tiny little senco that we we take out for a single finish gun or pin nailer, to the last which was the Dewalt (not a fan of their tools but...) 200psi oilless single tank which is still running to this day.
Cant honestly say if any of them would run any type of conventional or HVLP gun because it seemed a fools errand unless we were trying to run an airbrush.
I cant imagine trying to spray anything with air falling off, crappy air quality, and so on. The turbine would be the best option for something that would spray all day in a condition that was needed.
12/7/20       #7: Air compressor ...
Thanks for all the great ideas. Does anyone have a ball park figure of what that little turbine unit would cost? Will it spray everything?
    • Wicked Cool Tools
      Make cabinet door parts 3x faster with the UNO2
    • Western Dovetail
      Custom Made Dovetail Drawers
    • WalzCraft
    • CabinetCRUNCHER
    • Steve H. Wall Lumber Co.
