Subject: Re: Air Tool Oil Versus Compressor Oil
8/18/21
David
Good morning all from "Down Under", Australia. Just looking for some guidance if there is any real difference in these two oils, SPTools, being the brand we normally use.
I have used them interchangeably recently when I could not get any Air Tool Oil, using it in our Nail Guns but also in the Bosch misters of my CNC Routers. One of my new CNC operators pulled me up and maintained they were different and only Air Tool Oil should be used in the Bosch misters. The oils look visually the same and I would have thought the Compressor Oil may have only had some heat resistant properties over and above the air tool oil. Any comments and or suggestions most welcome. Thanks again David
8/18/21       #2: Air Tool Oil Versus Compressor Oil ...
rich c
You are asking about the oil that goes in the crankcase of the compressor vs the light weight oil that lubricates the internal parts of air tools? Crankcase oil is similar to 20 or 30 weight automotive oil. Air tool oil has special rust inhibitors and is very thin. Interchanging the oils will cause problems in either.
8/18/21       #3: Air Tool Oil Versus Compressor Oil ...
David Member
Thanks for that confirmation, regards
8/20/21       #4: Air Tool Oil Versus Compressor Oil ...
Air tool oil does not damage the fragile o-rings in the tool. Nail guns have several. Its also very thin. Most oils have "additives". They can damage or preserve different materials.
8/22/21       #5: Air Tool Oil Versus Compressor Oil ...
David Member
Thanks Adam
    • Western Dovetail
      Custom Made Dovetail Drawers
    • CabinetCRUNCHER
    • Steve H. Wall Lumber Co.
    • WalzCraft
    • Wicked Cool Tools
      Make cabinet door parts 3x faster with the UNO2
