Subject: Re: Squaring Slider Saw
Squaring Slider Saw
5/4/22
Brent Member
Website: http://www.parkhillwoodcraft.ca
I have a unique issue as I'm working to square the fence on my slider saw. With a 4x4' piece of 1/4" MDF, I use the 3-cut method (initial first straight-line cut goes against the fence, then make 2nd cut and then flip top face 180deg and make third cut) to set the the fence so the workpiece's measurement against the fence equals that furthest away from the fence. This would make the fence square to the sliding table. After having done this, I take a smaller part (maybe 18" x 18") and do the same process and I find the part's length nearest to the fence is greater than the edge furthest from the fence (so I've cut a trapezoid). Why the difference?? Any thoughts on what gives or am I just missing something? The fence itself is as straight as I think it could reasonably be. I'm stumped...
5/4/22       #2: Squaring Slider Saw ...
Fence bent?
5/4/22       #3: Squaring Slider Saw ...
Brent Member
Fence straight.
5/5/22       #4: Squaring Slider Saw ...
Does the work piece register against the fence or on the face of the sliding stops? If it is the stops then you will have to make sure the sliding stops are the same thickness as the fixed block nearest the blade. Any difference between the two will give you variable angles depending on position.
5/6/22       #5: Squaring Slider Saw ...
Brent Member
The workpiece registers against the fence, and the stops are square to the fence itself. I know what you're thinking... I'm confused too!
5/7/22       #6: Squaring Slider Saw ...
Bruce H
Do a 5 cut instead of a 3. it's more accurate, easily measured on the last cut.
5/8/22       #7: Squaring Slider Saw ...
I would remove the fence and clean it and under it. Run you fingers over the registration surface for dings or crud. Check that the end cap is flush with the face.
Another possibility is how you are holding the smaller piece. Is it that you are slightly shifting the work as you push it through? If you are pulling the finished cut back through the blade it may be that the slider has play. you would notice dust on the return stroke.
5/14/22       #8: Squaring Slider Saw ...
Dave Edgerton  Member
Agreed use 5 cut method
    • Wicked Cool Tools
      Make cabinet door parts 3x faster with the UNO2
    • Western Dovetail
      Custom Made Dovetail Drawers
    • WalzCraft
    • CabinetCRUNCHER
    • Steve H. Wall Lumber Co.
