Miter fold
11/9/17
Has anyone had any luck with a hand held router using a v bit for miter folding solid surface? Have you ever used a CNC insert bit in a hand held router?
11/10/17       #2: Miter fold ...
Stuart Douglas
Never done it, but if you have the patience I dont see why it would not work. The issue you'll run into is that the two reference surfaces must be co-planar for this to be successful. That is, the router base and the sheet must be in complete contact (while riding the straight edge) throughout the cut, and precise bit height must also be observed.
This is a cut you MUST rough out as much waste as possible, and finsih with a very light final cut. This is a very tall order for a hand held. I'd see if there is a local shop with a CNC setup that can accomodate your task, It will pay for itself in time alone, and IMHO, the risk of trashing the material. I do this on a CNC curently and even then I don't leave the machine for these types of cuts because things can go bad quickly.
I do use an insert bit and step it down only a 32nd at a time after rooughing out. You must remember that when you are doing this by hand you will have forces on bothe cutting sides, so you might need to trap the router base as opposed to just riding on one side.
11/11/17       #3: Miter fold ...
bill
Did you ever hear of a Betterly V groover sold by Penski Edge it does a very nice job look it up. If you don't like the price pm me I have one possibly for sale. I am in Pittsburgh Pa. but could ship it.
11/11/17       #4: Miter fold ...
Thanks for the response. I am trying to develop a technique for miter folding with a hand router. I have used a table saw with success, but I was thinking a router would be better.
The Betterly is out of budget, along with a CNC, so I thought I might come up with something.
I still need to add a radius corner( larger than 1 1/2") to the miter fold also.
