Help with running harlan laminator
3/23/20
Juan Member
Need help with heat settings on nip rolls and crome rolls. Double sided so I have 1 nip on top with 2 Crome mirror image on bottom. Top side runs fine but I have issues running bottom side, I get wrinkles on board. I run EVA glue nip heat set at 220 Crome heaters at 180. What causes the wrinkles ? Is there a form or link with help ?
4/23/20       #2: Help with running harlan laminator ...
Help Member
Review you glue settings. Too much glue can cause excessive wrinkling from the bottom side. Check you brake settings. Too much brake will cause wrinkles. If the wrinkle is long (Over 3-4"), more likely tension inside the board or even running of the board. If wrinkle is short, look at your bow roller and especially your index station
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
