Metal Laminate Over 1/2" Mdf Fail
2/6/21
Geoff
I made an open cabinet with a 4' x 4.5' x 1/2" mdf back. Prior to putting on the back I laminated metal laminate with contact adhesive to it. One coat of glue on laminate and two coats on mdf. The bond seemed fine but now some bubbles have appeared.
I did the sides the same way but with 3/4" mdf and no issues.
I should also mention the 1/2" back developed a significant bow. Convex toward the laminate side.
Looking for advice on repairing the back. Although I think that is wishful thinking. I do have access to a vacuum press(?).
If I have to remake the back should I laminate both sides? Anything else?
Geoff
2/7/21       #2: Metal Laminate Over 1/2" Mdf F ...
Thomas Gardiner
Ignore balanced layups at your peril. By applying glue and laminate to one side only you have possibly, introduced moisture from the glue and inhibited the absorbsion/evaporation of atmospheric moisture from the substrate on one face only. It is the winter so likely the substrate has a high relative humidity coming from the stack of freshly manufactured mdf and wil subsequently lose humidity in the low relative humidity of the heated shop. So the mdf shrunk (shrank?) but the laminate has captured the one face dimensionaly. That is why you have bubbles of localized glue failure due to shear stress and also the convex panel.
can you fix it? Probably not but you could try. I have had limited success with misting a concave surface with water and waiting until the surface is dry before glueing. The warp is reduced but not eliminated. You have a vacuum bag so you could apply a backer laminate with PVA in the bag. This is closer to a balanced layup and will do double duty of swelling the back of the panel with glue moisture. Don't expect miracles but it might work.
You still have the bubbles to deal with. Until you flatten the panel don't try to fix the bubbles. If you get a flat panel after applying plam to back then you can first try a hot iron on the bubbles to reactivate the contact cement and roll out the area. Test that the iron won't ruin the laminate on some scrap.
I have heard of but not tried drilling from the back and injecting glue under the bubbles then pressing in the vacuum bag.
Good luck. Now you know what not to do next time.
2/7/21       #3: Metal Laminate Over 1/2" Mdf F ...
Geoff
Thank you. What you said makes total sense. Knowing what to do next time is going to be happening sooner then later.
2/26/21       #4: Metal Laminate Over 1/2" Mdf F ...
bill
In addition to moisture you created a bi-metallic strip situation. The lamainte is going to expand and contract with changes in temperature.
Again the solution is a balanced panel. I think we all do that once.....
3/28/21       #5: Metal Laminate Over 1/2" Mdf F ...
Geoff
I haven't been back here for awhile...
I remade the panel pretty much right away.
My project manager was mad and tried to get me to redo the work off the clock. He is new to our company and was informed that this is not company policy. I clocked in under "warrenty" work and we don't charge the cllient for replacement material (This project happens to be "Time and Material")
Anyway, I laminated the back with a basic solid color plastic laminate (Formica) and the exposed side with the metal laminated and the panel stayed flat and no delaminations.
Success!
Thanks,
Geoff
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
