Sawing and Drying
Subject:
air drying ash
1/18/14
wayne Member
I have 270 bf of quarter sawn ash that was cut last oct. I have it stickered in my shed air drying right now and I was wondering how long it would take to get to 10% mc. I live in NW Ohio so that tells you it's cold here right now. Will it beready this spring? The sawyer checked it after it was cut and it measured 52%mc.
1/18/14       #2: air drying ash ...
Tennessee Tim
Here's a guide that's posted on here of most areas.....IN Ohio to 10% ADing....IT AIN'T HAPPENING !!!
Looks like 12-14% average.
http://www.woodweb.com/knowledge_base/fpl_pdfs/fplrn268.pdf
A great small DH Kiln kit for your needs is one by Daren, a poster here sometimes and at WWT. My kiln is based on his plans, only SUPERSIZED to the MAX!!!!!! The Pink board was my first 2 set-ups using his plans.
1/18/14       #3: air drying ash ...
Gene Wengert-Wood Doc
I agree. The conditions is Ohio will not dry under 12% MC, but for furniture, cabinets, flooring, etc., you need no wetter than 7.0% MC. Note that if the conditions are 12% EMC, you will find that lumber will reach 20% MC in six warm months, and eventually 16%, but it will take a long time to reach 13% MC. A good kiln can dry 4/4 ash in two weeks.
1/19/14       #4: air drying ash ...
wayne Member
Thanks for the link TT. Since I don't have a place to store it once it gets to usable mc I guess I'll have to build something to dry it as I need it. Thanks .
4/7/14       #6: air drying ash ...
old 243
Wayne I am in Ontario, so weather kind of similar. You won't get much drying over the winter. My air dryed lumber stabalizes about 13%, but doesn't go lower till you kiln it. If you have a shed or workshop. you might build a tent over it and use a dehumidifier, and fan circulation. you would also need some heat. If you just want it down to 10% , you should be able to do this .Should be able to go lower as well, just takes longer. Won't be long till spring, you won't need as much heat then. Have fun Tom
