Sawing and Drying
Subject:
curve gang sawing
1/22/14
bob Member
curve gang sawing hardwood logs, what would be a primary cause of the linebar side of the log producing tapered lumber. If you have a link or links to similar problems and solutions I would appreciate it
1/24/14       #2: curve gang sawing ...
Gene Wengert-WoodDoc
How long is the line bar? With curve sawing, it needs to be really short. Otherwise, you will have exactly what you are having.
1/30/14       #3: curve gang sawing ...
bob Member
5' inside the gang box and a tail line bar on the infeed all temposonic positioners, all logs go through scanning system then curve canter prior to going through gang
