Sawing and Drying
Subject:
After sawing for about a year I haven't broke a blade
9/10/14
Rod Hays
I don't know why the blades haven't broke, I had a turner mill and I think I broke one blade on that mill over the years I had it. Must be the tires I figure.
9/12/14       #2: After sawing for about a year I hav ...
Brian
Do you have a tension gauge, and if so, how much do you apply to the blade? What size blade? I run 1 1/2" TimberKing blades at about 2000# with no real problems, my partner seems to think that 2500# is better but he breaks blades all the time; of course, he states it must be due to faulty blades. I'm curious about others' experiences. Thanx
9/12/14       #3: After sawing for about a year I hav ...
Rod Hays
I don't have a tension gage. I run 1 1/4 to 2 ''. I have trailer tires for band wheels.
9/13/14       #4: After sawing for about a year I hav ...
Steve N
I think rubber tires and lower tension are real easy on blades. For the rest of us the biggest blade breakers are worn belts where the blade hits the wheel and the flange on the guide wheels or bearings are too close behind the blade, the 1/16 to 1/8 the WM recommends is too close and when sawing hard the blade will flex around the flange causing the gullets to break . I run mine 1/4" behind the blade which Cooks recommends with excellent results getting up to 20 sharpening's on some blades when they get down to 1" wide from 1-1/4
9/16/14       #5: After sawing for about a year I hav ...
Dave Boyt
Blade thickness is another factor. Thinner blades = less stress when going around the bandwheels, and less chance of cracking. They need more frequent sharpening, though, and tend to wander more in the cut. Just one of life's trade-offs. In the three years I've run a Norwood mill, the only blade I've broken was due to a defective weld. Full profile sharpening also helps, since it gets rid of the microfractures that can become cracks. I'm sure the rubber tire also cushions the blade and helps dissipate the heat.
9/23/14       #7: After sawing for about a year I hav ...
Chris
That's amazing that you haven't broken a blade
