Sawing and Drying
Subject:
Bandsaw mill blade solution freezing during the winter
1/7/15
Ken
We are currently running a bandsaw mill outside in the cold.
We are using windshield washer fluid to lubricate the blades with 2 water to 1 windshield washer fluid ratio.
However, the solution is freezing up.
What is the best solution to use during the winter for cutting hardwoods?
1/7/15       #2: Bandsaw mill blade solution freezin ...
Steve chapman Member
I have had the same problem for years until I switched to diesel and completely solved the problem. Steve C.
1/8/15       #3: Bandsaw mill blade solution freezin ...
john Member
use it straight not blended
1/8/15       #4: Bandsaw mill blade solution freezin ...
Dale Lenz
Check out this site, don't use the salt.
http://www.bestenterprises.net/Winter.pdf
1/12/15       #5: Bandsaw mill blade solution freezin ...
Dave Boyt  Member
What species are you milling? Unless sap build-up is an issue, I mill dry, and never had a problem with heat build-up.
1/15/15       #6: Bandsaw mill blade solution freezin ...
Eric
On my TimberHarvester mill, my air cooled engine directs the cooling air over the drip tank (which is built into the head framing). This keeps the lubricants warm enough to drip. Maybe you can find a way to direct the engine exhaust toward your drip tank?
1/19/15       #7: Bandsaw mill blade solution freezin ...
Windshield washer fluid
