Sawing and Drying
Subject:
Band saw water tank refill
12/8/15
Philippe Member
Lifting up the 5 gallons water tank on my LT15 is hard for me. Of course I could just fill with 1 gallon, but I suspect a heavier load helps stabilize the saw. I wish there was a top opening that I could use to refill with a gallon jug for instance but with the side opening it is difficult. How do other folks do? Thanks
12/10/15       #3: Band saw water tank refill ...
Keith Newton
Phillippe, I've got the same saw, and getting to the age,,,,,,,,,, well, level of arthritis in my shoulders that I can relate.
A gallon of water weighs ~8#, so x 5 is only about 40#, which doesn't seem like much until the lift and rotation hits the no-go range.
One suggestion, is to stand the container on it's back while up there where it rides, and pour it in from smaller containers, or fill with a hose. Then all you have to do, is roll it over.
12/11/15       #4: Band saw water tank refill ...
Jim Member
Why not use a hose attached to a faucet? If it is too far away, how about getting a small drill powered pump to fill it from a bucket on the floor?
12/11/15       #5: Band saw water tank refill ...
Philippe Member
Keith: yes putting the tank upright is good, though by the time you do that and add a funnel, it becomes pretty tall. I don't have arthritis but rotator cuff injury and lifting high is uncomfortable. But this is a workable solution.
Jim: no garden hose for quite some distance :(. I could indeed put a small fountain or aquarium pump: good idea!
I was toying with using one of those sideway laundry detergent dispenser, they are a gallon (not to heavy) and would be plenty for a session of cutting, but I have to modify or remove the dispensing "button".
12/12/15       #6: Band saw water tank refill ...
Paul Member
Philippe, Here is a link to a 2 1/2 gallon jug with bottom dispenser. I think it will work for you. Just add the right size hose.
12/12/15       #7: Band saw water tank refill ...
Paul Member
Forgot the link:
Link
12/19/15       #9: Band saw water tank refill ...
old 243
I have what is called a jiggller hose. It is a siphon hose with a check ball in one end. I use mine to transfer fuel from a jug to a fuel tank. The fuel jug has to be above where you are transferring to. would work with any liquid. Just jiggle the ball up and down and the flow will start. old 243
12/20/15       #10: Band saw water tank refill ...
Philippe Member
It turned out that the tubing from the tank to the saw is too short to set the water container vertical to fill it as in Keith suggestion.
For now I just disconnect the tubing from the tank, the tank from the support, the cap from the tank, bring it down and refill with just 1 gallon. As it is freezing around here now, I just let the rest of the water drain after using the saw.
The tank has 2 openings, the large one is the lower one when in use. The other is just an air intake. So If I had a garden hose I still would have to do the same disconnects turn the tank upright, then reconnect and turn the tank sideways.
I guess the lack of a top refill port is due to the technique for molding those tanks.
2/22/16       #12: Band saw water tank refill ...
Kathy Sanford Member
According to me, you must use automatic refiller for your tank. It is bit costly, but at least you don't have to lift heavy weight with such injury.
aquaristic online
