Sawing and Drying
Subject:
Sawing timbers
12/13/15
logmaster Member
I have some nice Doug Fir, 40 footers 12" tops, that i'd like to cut to make a cabin ( compound dovetail corners- yes, i understand the difficulty cutting dovetails in fir) with flats on inside & out , keeping the taper & natural contour between logs to chink. They were cut green @ 3 years ago , debarked & decked. Though I havent cut into them yet I'm expecting the MC towards the center to be in the low 20's % range. Though they are very straight grained ( I wont use the ones with any appreciable spiral ) I'm wondering if I can cut 2 - 5 1/2" cants out of one log. ( I realize I will have one side of each cant wider than the other but can alternate them so the gaps are fairly consistent. However, am i asking for trouble by making one cut down the very center of the log? What effect can i expect from doing this? Would you recommend I just cut one cant from each log, keeping the pith in the center of the cant? Any insight is appreciated.
12/15/15       #3: Sawing timbers ...
Stevem
FWIW:
FOHC (Free of Heart Center) timbers are premium price because of less cracking and more stability (and it takes a bigger log). If you have heart center in a log it will crack. If the log will support it, I'd personally cut for the FOHC.
Getting two 51/2 " cants out of a 12" diameter log is going to be real close with one very narrow face.
There is at least some taper in the logs so you might want to do both assuming you don't need 40' lengths. Center the heart on the top cut and split the bottom cut(s) in half to give you the FOHC.
