Sawing and Drying
Subject:
Finishing air dried lumber
1/3/17
fallguy Member
I have some 2 year air dried 5/4 walnut running 12-14% MC. I would like to dry the lumber down to furniture grade. The stack is about 400 BF and it is currently in an unconditioned space in Minnesota (cold). I would like to use the lumber in a month or sooner. I have several options I've considered. I can put the lumber in a conditioned space at 70F for 4 weeks with some fans running, but my wife parks the car in there, so there is always moisture present. I can build an enclosure in that space to warm the lumber and keep it from the car moisture, but it is in the house and always with wood and heaters, doesn't help me sleep well at night. I can build a Gene Wengert styled solar kiln and maybe even run a heater in the kiln for 4 weeks. I tried to find a commercial operator, but can't find any interest for small batches. I'd like to get advice from forum contributors on how to eek out the last 5% MC, or whether I'm wasting time and should just build. Thanks.
1/3/17       #2: Finishing air dried lumber ...
fallguy Member
I checked today again and the lumber is running between 11 and 12% now after we planed, jointed and sawed to final width about a month ago. Thanks for any advice. Part of me wants to build with the stuff, but I will be doing some glueups to 18" width, so I am nervous about those joints opening if the wood dries.
1/3/17       #3: Finishing air dried lumber ...
Gene Wengert-WoodDoc
I wrote an article in Sawmill and Woodlot magazine about drying small quantities of lumber. I am not in town so I cannot look up the date, but they should be able to help. It included using a small heat room, which seems like what you need. You could put a few of them in your attic and when spring comes, the heat will dry them quickly. The 400 bf is likely too heavy to put all of the wood in the attic, especially during the heavy snow season.
1/3/17       #4: Finishing air dried lumber ...
fallguy Member
No attic available. Modern attics here are all unheated spaces anyhow. But a heated chamber in the heated garage I can do. I just need some advice on how the time/temperatures to work towards. I have both radiant floor heat and also forced air available to the pile, but can use lights and oil radiator heater as well, the former are less flammable, imo. Thank you Gene.
1/3/17       #5: Finishing air dried lumber ...
fallguy Member
I tried to find the article you wrote, but was unable.
1/3/17       #6: Finishing air dried lumber ...
At the low MC you have now, you cannot do further damage to the wood. So, heating the room to 85 or 90 F and holding about 40% RH for several weeks and then dropping it to 30% RH should be fine. Let the RH come up naturally from the water in the wood, so you need a family moisture tight room. When the RH is too high, you need to exhaust some air and bring in some outside drier air.
1/5/17       #8: Finishing air dried lumber ...
Bill Smith
Website: http://www.esf.edu/wus/
To help judge drying progress to desired %MC you might consider making a sample or two. They can be fairly small if you seal the end grain. You can work out the math from equations in most drying books; for instance as a basic example, if a piece weighs 1.14 kg when it is 14% MC, when the weight drops to 1.07 kg MC is 7%. Balance or scale availability and sensitivity are important. Monitoring with a moisture meter is good too, especially one with insulated pins where shell to core gradient can be determined.
