Sawing and Drying
Subject:
Joining wet planks
1/19/17
Jacobus Goosen Member
Is it possible to finger join wet-off-saw eucalyptus planks, that is for air-drying and then kiln dried
1/19/17       #2: Joining wet planks ...
Sure it's possible. But who knows what it will look like, or even if it will fit back together when it's dry.
1/19/17       #3: Joining wet planks ...
Gene Wengert-WoodDoc
I think you are wanting to run them across a jointer or in a planer..? A big problem Is wet chips. They are heavy. And can corrode metal if not remove promptly.
1/21/17       #5: Joining wet planks ...
Keith Newton
I think you will have problems due to the very high shrinkage as it dries, especially if you try to join QS or radial to flat sawn. Here are the specs. Radial: 8.2%, Tangential: 12.8%, Volumetric: 21.0%, T/R Ratio: 1.6
If I were you, I'd cut some green samples, then zap short pieces in the microwave until dry, to see how much they move.
1/27/17       #6: Joining wet planks ...
Gene Wengert - Wood Doc
I suspect the original question is about jointing wood and not joining wood.
