Sawing and Drying
Subject:
tooth set
4/2/17
dlahart Member
Sawing 24" to 28" oak logs. What is the best tooth set, or what set should I start with? Also I have a live oak that is 41"x 7'. Its hard as steel, and took 14 sharpening's of chainsaw to get through it. Any suggestions about milling it.
4/2/17       #2: tooth set ...
Gene Wengert - WoodDoc
Some trees are able to bring silica up the stem, but I do not think oak is one of them. I assume that you know how to sharpen a chain saw including the flat spot in front of the tooth that controls the bite in order to minimize rubbing. If the bite is too large, the amount of sawdust per tooth can fill the gullet. On a large log, often the gullet fills with sawdust before it leaves the cut, and then the chain merely rubs, heats and dulls. This would seem to be most likely why you have an issue, unless the oak was dead and had dried out. Dry oak is twice as strong as wet.
Is the set you need for a band saw for a small mill? Do you have a setter? What width blade?
4/2/17       #3: tooth set ...
David LaHart Member
Thanks for your response.
I am one of few in my area that can make even chips fly out of a chainsaw. So yes. This oak is harder than dry oak, and it is alive. The cut I have looks like ceramic tile. I'll get you a pic. of it. Have a friend sharpening and setting my mill blades. Am looking to purchase a Cooks Cat Claw kit and trying to do my home work before it gets here. Again thanks
