Sawing and Drying
Subject:
Kiln Advice
4/21/17
Ivan Moses Member
Website: http://hillcountrydoors.com
The company I work for has plans to open a sawmill with a kiln. I have heard of a wood kiln that is actually lined with wood. From what I understand helps speed the drying process and allows you to dry multiple species at the same time. I have not been successful in finding information via Google. I am looking for the best way to dry 2000-300 bdft at a time. We can build out what ever kind of structure is needed. Any help would be greatly appreciated.
4/23/17       #2: Kiln Advice ...
Gene Wengert - WoodDoc
The wood lined kiln is not functional in the US for hardwoods. You need a dehumidifier type kiln.
8/8/17       #3: Kiln Advice ...
richard robey Member
Website: http://louisa hardwood products.com
i built a small (13x13)kiln,for specialty wood,spalted maple,hickory,burlwoood & live edge slabs,i used a small squirrel cage fan and a dehumidifier,lined it with mylar paper and it works great! never expected it would work as well as it does,i can bring it off the mill & have it dried to an average of 10% in 8 days,in the process of adding another 24x48 kiln using the same technique,great way to go
2/15/18       #4: Kiln Advice ...
terry will Member
was your dehumidifier kiln indoors i am trying to decide on something to speed up my drying i have a solar kiln but the Iowa winter does not work so well how much heat did you have would a small 1500 watt heater work. thanks
