Sawing and Drying
Subject:
drying wood in a hot box
6/27/17
BigJim
Website: http://bigjimsbowcompany.com
I am trying to dry wood from around 10% or less to near 0% or as close as possible for stabilizing.
The wood sizes are typically 2" x 2" x 18" or slightly larger and the hot box's are capable of reaching temperatures of 180*-190* and stored outside.... Location is South Georgia and operating throughout the year.
Will I need to add fans in addition to the vent holes in the cabinets? Will I need to increase the temp to above 212* to bring the mc low enough to achieve below 3 or 4%??
I had been baking the wood in an actual house hold oven at 220* for as long as 6 and sometimes 7 days to achieve desired affect, but the oven only holds about 20 blocks whereas my new to me industrial kitchen warmer will hold 100 or more.
Any advice on where I might go to find the answers to these questions would also be of great help.
Thanks, BigJim
6/28/17       #2: drying wood in a hot box ...
GeneWengert-WoodDoc
The humidity determines the final MC. Do you need 4% MC final (which does seem dry as most homes seldom go under 6% MC)? So, this means about 26% RH at 150 F. See DRYING HARDWOOD LUMBER in the archives here at WoodWeb, pages 16 and 17 for a complete range of data. High heat over 180 F makes wood brittle, darker in color and possibly weaker.
6/28/17       #3: drying wood in a hot box ...
BigJim
I'm actually trying to dry below 4% if possible. Once the wood is as dry as I can get it, I will be stabilizing it.
Any moisture left in the wood not only displaces the stabilizing resin, but has the potential of locking up the pump (been there done that).
Much of the wood is not structurally sound to begin with such as burls and spalted, but the stabilizing changes that considerably.
Thanks, BigJim
6/28/17       #4: drying wood in a hot box ...
Tennessee Tim  Member
BigJim, here's a link to one of the many stabilizing products... https://www.turntex.com/ FROM what I've looked into there seems to be a issue with many not getting their pumps and vacuums set-up correctly or doing in too much haste. NO I haven't actually done any yet BUT I've been reading up with the pros and cons getting ready to purchase a system.
BEAUTIFUL bows!!! I remember learning to shoot my first bow in scout camp 40 yrs ago on a traditional style bow. I've shot and hunted when time allows , natural with no sights or releases.... it is on a compound now BUT I miss the traditional feel.
6/28/17       #5: drying wood in a hot box ...
I forgot to ask what system are you using and how its set-up?? How are you prepping the wood prior final drying??? ADing , KDing, straight off saw etc., etc.
Check out my website, I saw the odd stuff and there's parts I could stabilize for more productivity/ less waste.
6/28/17       #6: drying wood in a hot box ...
BigJim
Website: http://Bigjimsbowcompany.com
Nice work there Tim.
I've been successfully stabilizing wood for a little while. Yeah, I have had a failure or two also but that's part of it.
I'm running up to 8 tanks at a time but having trouble keeping up with the supply of dry wood.
I have lots of wood from all over the world waiting...hard soft , even mildly rotten, but don't have the time to load and un load a little oven ...not to mention the baby sitting because of the high heat (relative). Accidentally burnt up $500 worth of exotics when the spalted caught on fire in the oven.
Took everything but the oven with it.
Thank god this stuff is all outside my shop.
That is why I was hoping I could load this warming oven with a 100 or so pieces of wood. Turn up the heat to 180 or 190
..that is the max and let it dry for a couple weeks or even a month or so. I could even reverse the fan to draw air out.
If it worked, I would buy two more units so I would always have dry wood waiting for stabilizing.
Thanks, bigjim
7/23/17       #7: drying wood in a hot box ...
Gene Wengert-WoodDoc
Drying wood that hot can reduce the strength. It also makes the wood more brittle. Of the various stabilizing products I have been acquainted with, none require or perform better if the wood is dried to the level you indicate.
