Sawing and Drying
Subject:
Drying wood prior to using kilns?
8/6/19
Grant Member
I am new to the sawmill world, but a long time carpenter. I am wondering how wood was dried prior to the use of kilns. Was it stacked, stickered, and allowed to dry for years? Or, was it sawn and immediately used?
8/6/19       #2: Drying wood prior to using kilns? ...
GeneWengert-WoodDoc
You can learn about this at Colonial Williamsburg, where wood was stacked and air dried and then was brought into the shop and stored in the rafters of the heated shop. This resulted in dry wood.
Appreciate that humidity in a home was higher in the olden days before central heating, so excessively low MCs were not required. Also, I do believe that most furniture was utilitarian and not necessarily as beautiful with huge flat surfaces, tight fitting drawers, etc. so, a little movement and accompanying shrinkage or swelling was tolerated. Also, more attention was paid to grain angles, and with larger trees, lumber was less subject to warp.
Also appreciate that shops were small, so large amounts of dry lumber were not required. It is with the urgency of time and the large plants, that faster kiln drying was required.
8/10/19       #4: Drying wood prior to using kilns? ...
My Great-Great Uncle owned a lumber yard in Emden, IL. It is still family owned, but being in a tiny farming community, it's just barely open. The building was designed for air flow through stickered bunks of wet pine that was brought in by rail. During the summer, windows were opened in two huge cupolas on the roof. Doors at the bottom of the outside walls were hinged on top and opened. That drew air all through the building. Today one of the cupolas remains, and of course the bottom doors haven't been opened in decades.
View higher quality, full size image (863 X 343)
8/10/19       #5: Drying wood prior to using kilns? ...
I should have added this picture of the Emden Lumber Co, before my Great-Great Uncle bought it. Here he was as an employee, standing in the doorway.
View higher quality, full size image (650 X 397)
8/11/19       #6: Drying wood prior to using kilns? ...
Was pine less susceptible to fungal staining back then? My understanding is that white pine is cut in the winter so it can be processed and in the kiln before the summer otherwise blue stains will degrade it.
8/11/19       #7: Drying wood prior to using kilns? ...
GeneWengert-WoodDoc
What encourages blue stain is slow drying in warm weather. The risk of blue stain in eastern white pine in the past 50 years has not changed. However, today EWP is sawn throughout the year, warm or cold.
