Sawing and Drying
Subject:
Rank 6 methods of stabilizing moisture level of small kiln dried boards
5/12/20
Jenny Member
Hi everybody,
I am looking for good methods of stabilizing moisture level of small kiln-dried 8% MC solid-wood boards.
Which of the following six methods do you think are effective? Which one is the most effective?
Are there even better ways to maintain moisture level of wood?
Method 1: If boards are stored in a humid area, use a dehumidifier where you store the boards
Method 2: Store the boards in a vacuum-sealed bag
Method 3: Apply Titebond to the end grain of board
Method 4: Apply epoxy to the end grain of board
Method 5: Apply epoxy to the entire board
Method 6: Finish the entire board with 2K Polyurethane
Method 7: Use Cactus Juice+Vacuum to stabilize board
5/12/20       #2: Rank 6 methods of stabilizing moist ...
Jenny Member
My boards' dimensions:
Length: 24 inches
Width: 6 inches
Thickness: 1 inch
5/24/20       #4: Rank 6 methods of stabilizing moist ...
GeneWengert-WoodDoc
#1 will work well.
#2 will work well, but you can skip the vacuum. A little air when you seal or zip the bag shut is not an issue.
