Sawing and Drying
Subject:
spring or winter harvested wood: differences
3/14/22
RRickards Member
I am producing arrow shafts for the archery industry. I presently run white birch, with aspen to follow once inventory is well stocked.
I am burnishing the shafts ( after drying to 7%), and cutting on a doweller. My question is about the differences between wood cut with sap up, (spring/summer wood), versus winter. (I am in Manitoba, Canada).
I am finding that as I test different species of wood (both soft and hard) that the woods with more resin ( like cedar) tend to burnish more easily and consistently, than the birch and aspen that I have run. Can someone tell me of I would find the birch and aspen more apt to take on a nice burnish if they were cut in summer, where lignun is present? Thankyou.
3/16/22       #3: spring or winter harvested wood: di ...
GeneWengert-WoodDoc
There is no chemical difference between winter, spring and summer. Further, the moisture is the same, the resin content is the same, etc. (The sap run in the maple trees is a run right under the bark, but the difference is in movement of the sap, not variation in its chemistry.)
What is different is that the sawyer is warmer.
Also, in warmer weather fungi can grow, moisture can leave from the ends, and the bark can slip easier.
3/16/22       #4: spring or winter harvested wood: di ...
GeneWengert-WoodDoc
Incidentally, I assume you are splitting the log and then following the split in order to get straight grain.
I was at one pool cue marker that was just starting and he did not use splitting. He called me because the cues were warping.
5/25/22       #5: spring or winter harvested wood: di ...
John Waldrup Member
Website: http://www.johnwaldrup.com
I have a question that I thought was related to the subject (maybe not).
I have had some cherry to be fairly stable (warping, splitting issues, etc) after sawing and some that warped horribly. Can you tell me what the difference might be?
Also, I cut a box elder with a beautiful cherry red center. For about two minutes. Then it turned gray through and through. Why does some stay red (apparently) and mine turned gray.
John
5/25/22       #6: spring or winter harvested wood: di ...
Gene WENGERT-WoodDoc
In the warm weather, the various molds and mildew and blue stain fungi are active, so they can grow and stain the wood then.
Warp is caused mainly by the grain slope in wood, by the presence of special wood like tension wood, There are a few minor factors, like lumber from a sleepy log will tend to warp.
