Sawing and Drying
Subject:
RE: Bandsaw Ripping blades
3/11/22
Kenneth Member
Our shop has a Tannewitz bandsaw.
What is the ideal teeth per inch for the band blade when ripping wood?
Also, what width of the blade is best for ripping straight pieces of wood, and what width is best for curving or shaping the wood?
Thanks for your help.
3/16/22       #2: RE: Bandsaw Ripping blades ...
GeneWengert-WoodDoc
Is this for a sawmill? Or is this for a home shop bandsaw? Is the wood dried to 7% MC. Softwood or hardwood?
3/18/22       #3: RE: Bandsaw Ripping blades ...
The blade that spends 90% of the time on my saw is a 1/2" 3tpi skip tooth Bahco. They are inexpensive but last and rip soft and hardwood decently.
Google bandsaw blade radius chart and you can print a graphic of the turning radius for various blade widths.
The condition of the tires and what you have for blade guides will determine what blade widths will track on your saw.
3/18/22       #4: RE: Bandsaw Ripping blades ...
GeneWengert-WoodDoc
In general, for cutting dry wood, 3 or4 tpi is used. A smoother cut is obtained with 4 than 3
In general, a blade 3/16” wide will cut very straight and allow reasonable turns. A lot wider lade will not cut as straight and with many saws you cannot get enough tension on the.blade.
There are other factors, such as hook angle, metal type, tooth treatment, etc. the harder the wood, the more critical it becomes to have the correct blade.
2/26/23       #5: RE: Bandsaw Ripping blades ...
Chippy1987 Member
The most common and for general purposes would have to be either a hook-tooth blade or a 1/2 inch 3-tpi standard blade. A 3/8 inch 4-tpi will cover most jobs like ripping, cross-cutting, and resawing. The only hassle is changing blades and resetting the guides, tension, and tracking.
